| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Date created | 25 February 2016 |
| Date modified | 25 February 2016 |
In this movie we explain how to define rockbolts in the Tunnel Designer, available since PLAXIS 2D 2016.
Note: In newer versions of PLAXIS, the Rock bolts option inside the Tunnel Designer is now called Reinforcements.
