| Version: | V8, XM, V8i, CONNECT, 2023 | ||
| Area: | DWG | ||
| Subarea: | Save |
Unable to open seed file: seed.dwg
When saving as a DWG in MicroStation V8, error message is displayed:
"unable to open seed file: <seed file name>".
Even though MS _DWGSEED is set to a valid path, the error continues to display.
MS_DWGSEED is not set to a valid path.
Possible reasons:
1 - The file specified in configuration variable MS_DWGSEED is not a valid path to the seed file.
Change MS_DWGSEED to a valid seed file.
2 - If the location was defined in DWG options, it will be stored in the dwg data files and the configuration variable will not be applied.
Open DWG options and change "DWG Seed File" to a valid location and seed file name.
3 - The DWG seed file was set to a DGN format file.
Open DWG options and change "DWG Seed File" to a valid seed file that has the DWG file format.
Note:
If DWG data files are replaced with new ones, the MS_DWGSEED will again be used to define the location of the DWG seed file.
