| Application | PLAXIS 3D |
| Version | PLAXIS 3D |
| Date created | 09 May 2011 |
| Date modified | 09 May 2011 |
In addition to the Generating a mesh video, here we learn some more advanced tips how to improve your mesh.
In the most recent versions of PLAXIS, the "snaplinear" option can be used to more quickly connect different objects, such as the lines defining the embedded beams and the surface defining tunnel lining in the example shown in the video. For further information on this command, please refer to Command Reference. This feature is also shown in this Special Interest Group webinar (requires a Bentley account).
