| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 01 November 2013 |
| Date modified | 01 November 2013 |
Since PLAXIS 3D 2013 it is possible to run scripts written in the Python programming language. This functionality enables us to automate the workflow of an iterative design process. We can make quick changes to a model, using pre-defined design parameters.
In this video, we will create a Python script that generates a model for drivemining. The script includes soil, structure, mesh, staged construction and calculation.
This remote scripting functionality is now also available in PLAXIS 2D.
Click here to see the full workflow with the PLAXIS Remote scripting with the Python wrapper.
