| | Product: | MicroStation | |
| | Version: | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Curves | |
| | Subarea: | N\A | |
The Facet Curve tool inside Curves tool or Curve Utility tools can achieve this.
Facet to provides different options: Line strings, arcs, point, etc
You can also key-in DROP CURVE to get the Facet Curve Tool
The method used are distinct in the following methods:
- Equal Arc Length — The B-spline curve is evaluated evenly along the arc. Each segment has the same arc length, as defined by the value for Number.
- Equal Chord Length — The B-spline curve is evaluated at a given number of points such that the distance between each successive point is the same.
- Fixed Chord Length — The distance between each pair of successive points evaluated is the same as the chord length.
- Max. Chord Height — The maximum chord height for all of the line segments is less than the Chord Height.
- Equal Parameter Length — The B-spline curve is evaluated evenly in the parameter space by the Number value.
Note: To get more accurate results increase the "Number" value in the Facet Curve tool.
This value represents the number of segments used to approximate the curve.
See also
How to Drop a Bspline Curve
What happened to drop bspline curve tool?
Other language sources
Deutsch
| | Original Author: | Maria Munoz | |
