| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Date created | 25 February 2016 |
| Date modified | 25 February 2016 |
In the video, we show how to set-up the model discussed in the validation report below. The validation concerns the response of a rock mass due to circular excavation in a Hoek-Brown material with non-uniform in-situ stress. The initial calculation is performed with the Field stress calculation type available since 2D 2016.
