Tips and tricks for easier drawing
Application PLAXIS 3D
Version PLAXIS 3D all versions
Date created 09 May 2011
Date modified 13 April 2026
Keywords PLAXIS, geometry, surface, draw, decompose, extrude, 3D
This movie shows three methods to construct the three surfaces of an excavation.
  1. Drawing with vertical movement and snapping.
  2. Using movement limitation planes.
  3. Using extrude, decompose and delete.
