| Version: | V8i, CONNECT, 2023 | ||
| Area: | Text | ||
| Subarea: | Word Processor |
Unable to get a stacked fraction to display in MicroStation.
To get a stacked fraction to display in MicroStation Select Series 3, type a space before and after the fraction
[space]1/2[space]
becomes "1/2" stacked.
In order to place a visible space before or after your fraction, add a double space.
The Text Styles dialog opens.
The Text Editor window opens.
The Insert Stacked Fraction dialog opens.
Note: The Text Editor window supports fraction characters defined in RSC fonts. To enable this feature, the capability setting CAPABILITY_WORDPROCESSOR_USE_RSCFRACTIONS must be set. If a fraction character is present in the font, the stack fraction is replaced by this character.
To Place a Stacked Fraction with Auto-Stacking Off
http://communities.bentley.com/products/microstation/microstation_annotations/f/19566/t/77795.aspx
| Original Author: | Derval Canny |
