| Application | PLAXIS 2D |
| Version | PLAXIS 2D 2015 |
| Date created | 12 February 2016 |
| Date modified | 12 February 2016 |
This movie demonstrates how to set-up a model to predict the development of seepage around a pressure tunnel, where the groundwater table is situated far below the pressure tunnel. Full validation of the model against the analytic solution can be found in the document linked below.
