| Application | PLAXIS 3D |
| Version | PLAXIS 3D |
| Date created | 09 May 2011 |
| Date modified | 09 May 2011 |
Before calculation of a model, we have to generate a finite element mesh of the model. This video explains the basic knowledge for generating meshes.
Notes
- since parametric geometry is used in the most recent versions of PLAXIS 3D, the expert settings are solely defined in terms of relative element size (or, alternatively, element dimension);
- for dynamic analysis, additional requirements may be required to find an appropriate mesh to the problem.
