| Applies To | | |
| Product(s): | MicroStation | |
| Version(s): | System.Data.DataRowView | |
| Environment: | N\A | |
| Area: | Printing | |
| Subarea: | N\A | |
| Original Author: | Frank Reimann, Bentley Technical Support Group | |
Problem:
A PDF file is created using the Bentley pdf.pltcfg Printer Driver configuration file in a freely selected directory. The Windows Explorer should now open this directory automatically after the PDF creation process finished.
Thus, the Windows Explorer automatically opens with the freely selected directory, you have to edit the pdf.pltcfg Printer Driver configuration file as follows:
Programs TAB -> Checkmark in Define pre-print and post-print program commands -> Add .. ->
Program Command: c:\windows\explorer.exe $(MS_PLTOUT)\..
When to execute program: After printing
OK
