| Application | PLAXIS 3D |
| Version | PLAXIS 3D 2010.01 |
| Date created | 09 May 2011 |
| Date modified | 09 May 2011 |
The different uses of prescribed displacements are explained in this video. To demonstrate how to apply displacements, a Confined Compressive Strength test is simulated in PLAXIS 3D as an example.
