| Issue status | Solved |
| First Affected Version | PLAXIS 2D 2017 PLAXIS 3D 2017 |
| Found in Version | PLAXIS 2D 2017 PLAXIS 3D 2017 |
| Fixed and Released in Version | PLAXIS 2D CONNECT Edition V20 Update 2 PLAXIS 3D CONNECT Edition V20 Update 2 |
| Issue # | SW-21183 |
| Date created | 06 June 2019 |
| Date modified | 29 April 2020 |
In the Groundwater tab of the Soil dataset, we can choose between different settings to give default permeability values:
The permeability values used for the last two can be found in the PLAXIS Reference manual in the sections about Hydraulic datasets and models and Saturated permeabilities.
When you change the option Use defaults for an existing dataset from From data set to None, the values for kx, ky and kz (3D only) are internally not updated but kept at the same values when using a PLAXIS CONNECT Edition V20 Update 1 or earlier. This also means that the calculation will take the earlier permeability settings as defined in the From data set configuration.
The changes are stored correctly when you e.g. create a new material dataset, when you change the Use defaults to From grain size distribution, or when you change from From grain size distribution to None. This issue only happens when you change the Use defaults from From data set to None for an existing material dataset.
The issue has been resolved since PLAXIS 2D CONNECT Edition V20 Update 2 (20.02.00) and PLAXIS 3D CONNECT Edition V20 Update 2 (20.02.00)
For older versions, please check the material set’s permeability settings.
When the hydraulic conductivity values kx, ky and kz (3D only) are not updated to your values, please follow these steps:
This will store the hydraulic permeabilities correctly.
See also the attached video
