| Application | PLAXIS MoDeTo |
| Issue status | Solved |
| First Affected Version | PLAXIS MoDeTo CONNECT Edition V20 |
| Found in Version | PLAXIS MoDeTo CONNECT Edition V20 |
| Fixed and Released in Version | PLAXIS MoDeTo CONNECT Edition V20 Update 2 |
| Issue # | SW-46210 |
| Date created | 24 February, 2020 |
| Date modified | 14 May, 2020 |
In PLAXIS MoDeTo CONNECT Edition V20 (release of January 2020), the Save Selection and Save All options generate an empty .TSV file when used with rotational soil reaction curves (moment-rotation and base moment-base rotation).
This is now fixed in PLAXIS MoDeTo CONNECT Edition V20 Update 2
Workaround for older versions: Choose ‘Copy Selection’ or ‘Copy All’ and then paste the table data to its destination. A TSV file can be created with any plain text editor
