| Version(s): | 08.11.07.443 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Larry Abla, Bentley Technical Support Group | ||
The 3D pdf file I just created with MicroStation Print won’t rotate in Adobe Acrobat.
The problem could be that the data is too far from the camera.
In this scenario, there was a flat shape element 60,000 feet above the design plane. After that shape was deleted, the 3D PDF file rotated correctly.
