| Version(s): | 08.05.02.xx | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Edwin Yepes, Bentley Technical Support Group | ||
Can wildcards be used when naming the cell that will be the plot boundary when using Print Organizer? Example: a print definition may include drawings which have one of following cells border_v1, border_v2,border_v3 etc. Can I specify border* or something similar?
The following are examples you can use in the cell name field within the Print Area :
followed by zero or more of any other characters.
border_v:n - Finds all cells beginning with "border_v" followed by a single alphanumeric character
More explanation on what your choices are can be found on the online help,
