| Application | PLAXIS 2D |
| Issue status | Open |
| First Affected Version | PLAXIS 2D 2018.00 |
| Found in Version | PLAXIS 2D CONNECT Edition V20 Update 2 |
| Fixed and Released in Version | PLAXIS 2D CONNECT Edition V20 Update 4 |
| Issue # | 379697 |
| Date created | 1 July 2020 |
| Date modified | 30 September 2020 |
The Deconfinement (1-β) method is used to simulate the three-dimensional soil arching behaviour that occurs around an unsupported tunnel face when using a 2D model, like PLAXIS 2D.
There are two ways to set this up in PLAXIS 2D:
A deconfinement value can be entered during staged construction as 1-β in the model explorer for any selected and deactivated soil cluster (see figure below). This method intends to give similar results to those obtained when using the partial staged construction (ΣMstage) method while bringing additional flexibility since different deconfinements can be applied to different tunnels or different sections of the tunnel in the same phase.
However, this Deconfinement option may give unexpected results in PLAXIS 2D CONNECT Edition V20 Update 3 or earlier when pore water pressure changes in the tunnel, for instance when dewatering the tunnel during the excavation process. When using the Deconfinement method, the effective stress changes are solved according to the defined deconfinement value, while all pore water changes are fully solved in the same phase.
This is now solved in PLAXIS 2D CONNECT Edition Update 4.
