| Version(s): | 08.11.09.459 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
A linked Excel file should be printing white but is printing black when creating a PDF.
Define the following variable in your workspace configuration, then close and restart MicroStation.
MS_PLT_ENABLE_OLE_TRANSPARENT_BACKGROUND=0
