| Version(s): | 08.11.07.443 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Van Kendall, Bentley Technical Support Group | ||
I am getting an error when plotting to the Adobe PDF printer using printer.pltcfg.
The error is “[StartDoc] The specified datatype is invalid”. The error happens when plotting to a custom size (such as 22.0 x 157.0). The custom form was created using the Postscript Custom Paper Size option for the Adobe PDF printer.This seems to be an issue on Windows 7 64 bit only. XP works fine.
Set the Print Quality for the Adobe PDF printer to 600 or below.
To do this:
