| Application | PLAXIS MoDeTo |
| Version | PLAXIS MoDeTo |
| Date created | 08 November 2018 |
| Date modified | 07 January 2020 |
PLAXIS MoDeTo implements the PISA design method for the design of monopile foundations for offshore wind turbines, including large diameter monopiles.
The PISA joint-industry project (Phase 1: 2013-2016; Phase 2: 2017-2018) was a research study on the development of new design procedures for monopile foundations for offshore wind turbine applications. The project consisted of field testing, numerical modelling and design model development. The research was conducted by an Academic Work Group drawn from the University of Oxford, Imperial College London and University College Dublin and was conducted in collaboration with a range of project partners. One outcome of this study is a one dimensional (1D) design model, based on the use of Timoshenko beam theory, that overcomes certain limitations of existing methods.
The broad scope of the PISA joint industry project is summarised in recent publications:
PISA Phase 1: General description and methodology
PISA Phase 2: Layered soils extension
Field tests
Validations and applications: Homogeneous soils
- Minga, E., Burd, H.J. (2019). Validation of PLAXIS MoDeTo based on the Cowden till PISA field tests. Oxford University, Oxford, United Kingdom.
- Minga, E., Burd, H.J. (2019). Validation of the PLAXIS MoDeTo 1D model for dense sand. Oxford University, Oxford, United Kingdom.
- Panagoulias, S. et al. (2018). An Innovative Design Methodology for Offshore Wind Monopile Foundations. In: 26th European Young Geotechnical Engineers Conference, Graz, Austria.
- Panagoulias, S. et al. (2018). Application of the PISA framework to the design of offshore wind turbine monopile foundations. In: WindEurope 2018, Hamburg, Germany.
- Panagoulias, S. et al. (2019). Design of Offshore Monopile Foundations Using the PISA Methodology. In: Offshore Wind International Partnering Forum (IPF 19), New York City, New York.
- Kaltekis, K. et al. (2019). Comparative concept design study of laterally loaded monopiles. In: WindEurope 2019, Bilbao, Spain.
- Brinkgreve, R.B.J. et al. (2020). Validation and application of a new software tool implementing the PISA Design Methodology. J. Mar. Sci. Eng. 2020, 8, 457.
- Panagoulias, S. et al. (2020). Concept Design Study of Laterally Loaded Monopiles in Sand. In: International Symposium on Frontiers in Offshore Geotechnics (ISFOG21), Austin, TX.
Validations and applications: Layered soils
