| Version(s): | V8i, CONNECT | ||
| Environment: | Windows 10 | ||
| Area: | |||
| Subarea: | Organizer | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
Getting the following error when attempting to add design file print definitions to Print Organizer:
Exception encountered inside [WorkerMicroStationProxy.LoadDesignFile]
Message Details:
"There was no endpoint listening at net.pipe://localhost/6f5fc636-d3ea-45e8-9abd-149f40fa787a that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details."
Known Solution #1 - Reinstall .NET Framework
Known Solution #2 - Run MicroStation as administrator
Some other troubleshooting steps to try:
- Uninstall MicroStation and then reinstall as administrator (right-click .exe install file and run as administrator)
- Repair existing .NET framework on machine
- Log onto machine with another user profile and check if the issue persists
