| Version(s): | 08.11.09.357 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
How is the RGB value calculated when using “Print in grayscale” color mapping in a pltcfg? In other words, if color 4 (255,255,0) is mapped to “Print in grayscale” what gray RGB value is used?
When using grayscale color mapping the following industry-standard grayscale conversion formula is used:
30% red + 59% green + 11% blue.
For example: color 4 (255,255,0) converts to 76.5 + 150.45 + 0 = 226.95 which is (226.95,226.95,226.95), rounded to (227,227,227)
Same applies when using the “Grayscale” color setting in the Print Dialog.
