| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
How are levels (layers) included in a PDF created with MicroStation printing?
Enable “Optional Content” in the pdf.pltcfg Printer Driver Configuration file. Using the Print Dialog select File > Edit Printer Driver Configuration. After setting “Enable Optional Content” to “On”, save the changes and reload the Printer Driver Configuration under the File menu in the Print Dialog.
