| | Applies To | | |
| | Product(s): | MicroStation | |
| | Version(s): | System.Data.DataRowView | |
| | Environment: | N\A | |
| | Area: | Printing | |
| | Subarea: | N\A | |
| | Original Author: | Frank Reimann, Bentley Technical Support Group | |
How can I allow paper size editing in the Print Dialog Box?
Using a default MicroStation installation Allow paper size editing is switch OFF.
You can active this setting as followed:
Open MicroStation -> File -> Print -> the Print Dialog box is open -> Settings -> Preferences -> User Interface -> make a check mark in Allow paper size editing
Now you can active edit the paper size
It is also possible to set this setting permanent setting the MicroStation Configuration variable
MS_PLTDLG_ALLOW_FORM_SIZE_EDIT = 1
Allow paper size editing will display in gray if you use this variable:
Note:
The descript settings applies only to Bentley printer drivers.
