| Version(s): | N\A | ||
| Area: | Printing | ||
| Subarea: | N\A | ||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
How can you enter a user-defined rotation in the Print Dialog box?
Go to MicroStation -> File -> Print... -> Print Dialog box is open -> Settings -> Preferences -> User Interfaces -> Remove the checkmark " Hide advanced layout controls"
