| Version(s): | N\A | ||
| Area: | N/A | ||
| Subarea: | N\A | ||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
User would like to disable the File-> edit printer driver option from the print dialog.
Edit the following via workspace->configuration
MS_PLTFILE_EDITOR = HIDE_MENU_ITEM
