| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Date created | 06 November 2012 |
In the attached document a case study on the use of the embedded pile row feature in PLAXIS 2D is given, and the results are discussed. The introduction includes a brief description of the embedded pile row implementation and its parameters.
