| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Edwin Yepes, Bentley Technical Support Group | ||
How do I control the setting under Settings->Raster Options-> "Honor transparency in raster references" within the Print Dialog? I want it to be unchecked by default.
The .plt record "no_raster_transparency=1" may be used to disable raster transparency within a printer driver. This record is an alternative to the MS_PLT_NORASTERTRANSPARENCY configuration variable.
