| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group | ||
How do I turn on/view the Geo Referencing ability in the PDF file created by MicroStation Print?
Make sure Enable Georeferencing is ON in the pdf.pltcfg (under Base Properties - Driver Properties). To display the longitude/latitude values in Acrobat (Reader or Professional) 9.0 or later, select Tools >Analysis > Geospatial Location Tool. To properly display longitude/latitude values for maps that were drawn with a NAD27 grid,you will need to change Acrobat's Geospatial Measuring preferences (Edit > Preferences > Measuring (Geo) .
