| Version(s): | 08.11.05.17 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
How do you save configuration files (.ini) files as a print set files (.pset) which can be used in MicroStation V8i printing?
From the MicroStation Print Dialog Menu, take the following steps:
File>Open Print Definition>browse to .ini>File>Save Print Definition
(save a .pset)
