| Version(s): | 08.09.04.88 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
How do you set a default scale value in the plot driver file (*.plt or *.pltcfg)?
For *.plt plot driver files:
1) File>Edit Printer Driver Configuration File
2) Add the following string: default_scale=xx (where xx = scale value)
For *.pltcfg plot driver files:
2) Choose the Paper Size tab, check "Define paper sizes", choose "Add",then check the box "Default Print Scale" to give it the scale valuedesired.
