| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | N\A | ||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
Problem Description
What is the format to append the filename with some additional text, such as "-Detail", so that the default pdf file name would
be filename-Detail.pdf.
Steps to Resolve
Edit pdf.pltcfg via Default print filename
Your "File Name" property will read:
$(MS_PLTFILES)$(basename(_DGNFILE))-Detail
note where I have appended -Detail.
