| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
With a pset from someone else that looks for files in a different location from one machine to another how do you make the pset look in another location.
In print organizer do a edit-> find and replace file paths..
from here give the "find what" the original path
give it the new path under the "replace with" field
then select print definition.
