| Application | PLAXIS 3D |
| Issue status | Solved |
| First Affected Version | PLAXIS 3D CONNECT Edition V20 Update 4 |
| Found in Version | PLAXIS 3D CONNECT Edition V20 Update 4 |
| Fixed and Released in Version | PLAXIS 3D CONNECT Edition V21 |
| Issue # | 499737 |
| Date created | 07 December 2020 |
| Date modified | 25 January 2021 |
The design of tunnels usually involves the use of structural elements, including the reinforcements of the tunnel. In PLAXIS 3D's Tunnel Designer we can define girders (ribs, wailings etc.) along the perimeter or around the cross-section of a tunnel at slice boundaries, by assigning a beam to the line or polycurve between two adjacent segments in the Plane Properties.
Unfortunately, in PLAXIS 3D CONNECT Edition V20 Update 4 (CE V20.04) when girder beams are assigned to arc segments of the tunnel cross-section, we see that the beam arcs are generated in the wrong direction when using the Generate Tunnel action, leading to incorrectly defined tunnel geometries:
We solved this issue in PLAXIS 3D CONNECT Edition V21 (released January 25).
When these girders are needed in your design, please do not use PLAXIS 3D CONNECT Edition Update 4 (CE V20.04).
