| Version(s): | 07.01.05.03 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
What entry do I need to add or modify in the MicroStation J printer.plt file to produce a Black & White printout
Open printer.plt file with notepad and add the following entry:
num_pens = 1
