| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Evert de Jong, Bentley Technical Support Group | ||
How to get printer information from a command line.
The following key-in will create a file called PrinterInfo.
for %a in (PRINTER PRINTERCONFIG ) do wmic/append:C:\Users\PrinterInfo.htm > nul %a get /format:htable
See: WMIC /?
From command line for more options
NB: You must have access to the output directory. Otherwise the error message: Invalid File Name appears
