| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
How to open a existing Print set file (*.pset) from the MicroStation Key-in instead of using Print Organizer -> File -> Open
mdl keyin Bentley.MicroStation.PrintOrganizer,PrintOrganizer PrintOrganizer dialog;printorganizer open Your_pset.pset
