| Version(s): | 08.11.07.443 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
How to print 11x17 paper sizes using pscript.pltcfg.
Edit pscript.pltcfg as follows:
1) Select Paper Sizes> add "11x17" (or "ANSI B")
2) Under Base Properties>Advanced>choose "Prolog File Name" browse to and select "HPTTABL1.PRO".
3) Save changes and reload printer driver.
Note: Canon printers may not understand the entries in the HPTTABL1.PRO file. One workaround is to edit HPTTABL1.PRO and replace the "Tabloid1" entry with "11x17". This worked for a Canon IR 5075 PS3.
