| Version(s): | 08.05.02.35 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
User would like to print cells in a Microstation cell library.
CellUtils is a utility that provides you with the ability to group cells in a grid to be placed in a design file. The grid can be plotted to create a book of the cells. The dialog displays the modification time date stamp of the Model or cell.
Go to this Be Communities link for more information regarding this utility:
