| Application | PLAXIS LE |
| Version | CONNECT Edition V21 |
| Date created | 25 January 2021 |
| Date modified | 25 January 2021 |
Dynamic Programming Advantages:
A conventional slope stability analysis involving limit equilibrium methods of slices consists of the calculation of the factor of safety for a specified slip surface of predetermined shape. The determination of the location of the critical slip surface with the lowest factor of safety is part of the analysis. To render the inherently indeterminate analysis determinate, conventional limit equilibrium methods generally make use of assumptions regarding the relationship between the interslice forces. These assumptions become disadvantages to limit equilibrium methods, since the actual stresses acting along the slip surface are quite approximate and the location of the critical slip surface depends on the shape assumed by the analyst.
Limit Equilibrium methods (LEM) of slices have two major shortcomings:
