| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
In some environments today are still the older HP DesignJet models in use.How to print from Windows 7 (64 bit) using a Windows driver to an "old" HP DesignJet 600?
You can use the following printer driver:
HP Designjet HP-GL/2Driver for Windows Server 2003 x64 Editions, Windows XP Professional x64 Edition and Windows Vista
