| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Ed Yepes, Bentley Technical Support Group | ||
When I use as Bentley Printer Driver Configuration file I want to be able to save my plot ready file to the same directory as the design file.
To modify a .plt?
Open your .plt with Notepad
Modify your 'default_outFile' record to read:
default_outFile/auto_overwrite = "$(noext(_DGNFILE))"
Please note that if the auto_overwrite option is used and a file with the specified name already exists, the file is overwritten by the new print file without confirmation.
To modify your .pltcfg
Select File->Edit printer Driver Configuration
Select the "Base Properties" tab
Expand "Default print File Name"
Look for "File Name". Enter $(noext(_DGNFILE))
Please note that if the "Auto Overwrite File" is set to True and a file with the specified name already exists, the file is overwritten by the new print file without confirmation.
