| Version(s): | 08.09.04.51 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
How to set a default paper size in the plot driver file *.pltcfg and maximize the size regardless of the size of the sheet model
being selected; this works manually (from the dialog) but not from the .pltcfg file.
Set the following MicroStation configuration variables:
MS_PLT_ENABLE_PRESERVE_SCALE=0 --> to setting of prevent previous scale
MS_PLT_MAX_ON_NEW_AREA=1 --> to maximize plot
MS_PLT_HONOR_SHEET_INFO=0 --> to disable honor the
sheet size
