| Version(s): | 08.11.07.443 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
How to transfer the print styles from a design file to a DGN Library file.
Open the DGN Library design file, do a File>Save As and give it a name with a .dgnlib extension. Place file in DGNLIB directory as defined in MS_DGNLIBLIST configuration variable.
