| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
How to use multiple expressions in the Pen Table "Level regular expression" field? Example: To test off all level names beginning with F and G.
In the Level regular expression field:
[F|G].*
This should test off level names beginning with F and G.
