| Application | PLAXIS 2D LE |
| Version | CONNECT Edition V21 |
| Date created | 25 January 2021 |
| Date modified | 25 January 2021 |
Option A: through PLAXIS Designer
In PLAXIS Designer: Import > File > Choose appropriate DXF contour file
Create:
1. Grid
2. Mesh
- Create Grid
- Select all polylines > Right Click > Convert to Grid via Kriging
Here you can adjust:
- kriging settings
- the density of your grid by clicking “Define Gridlines…” then choosing “Add Regular” and updating the settings.
- Click OK to generate the grid
- Create Mesh
- Select necessary Polylines > Right Click > Convert > To Mesh
Then transfer to PLAXIS 2D LE:
Do this by either:
1. Copy and Paste from PLAXIS Designer to PLAXIS 2D LE Surfaces
2. Create model volume in PLAXIS Designer, then generate PLAXIS 2D LE model
- Copy and Paste from PLAXIS Designer to PLAXIS 2D LE Surfaces
- In SVSLOPE:
- Geometry > Surfaces > New or Select an existing Surface > Properties
Note: surfaces are listed in order of highest to lowest elevation. - Definition Options: Choose Grid or Mesh depending on which type you have
- Paste from PLAXIS Designer
- Create model volume in PLAXIS Designer, then generate PLAXIS 2D LE model
- Create region to enclose the plan view extents of the volume
- New > Volume…
- Add and select appropriate region
- Add at least (2) surfaces
- Select appropriate surface(s) in order or highest to lowest elevation
- Set surface 1 as constant and set constant elevation
- Select Volume > Right Click > Actions > Generate Model > Specify model parameters > OK
Option B: with PLAXIS 2D LE
Create:
- Grids
- Meshes
- Grids
Note: Grids can be generated in PLAXIS 2D LE in similar fashion to how they are generated in PLAXIS Designer, using kriging. This is done in the Surfaces dialog.
- Geometry > Surfaces > Select Surface to edit > Properties
Note: surfaces are listed in order of highest to lowest elevation. - Definition Options: Grid
- Import Scatter Data > Import From File > Choose appropriate DXF file
- Select appropriate object (“contours for model”)
- Click OK to warning of duplicate points if applicable
- Define Gridlines…
This is where you can adjust the grid density
- Add Regular > Adjust accordingly for both X Grid Lines and Y Grid Lines
- Move to the Interpolations Tab to adjust kriging settings if necessary
- Generate
- OK
- Meshes
Note: meshes cannot be generated in PLAXIS 2D LE, only copied from PLAXIS Designer or other meshing platforms
- Copy mesh values
- Geometry > Surfaces > New or select existing surface to edit > Properties
- Definition Options: Mesh
- Paste mesh data
- OK
