| Application | PLAXIS LE |
| Version | CONNECT Edition V21 |
| Date created | 25 January 2021 |
| Date modified | 25 January 2021 |
SOILVISION Manager is now called PLAXIS LE Manager under CONNECT Edition versions, which is the platform that manages how all our software communicates with each other. Like in Microsoft Office - you can purchase any program (PLAXIS LE 2D, 3D or PLAXIS Designer etc.) by itself, or in combination with other programs, and they all have a common interface.
The PLAXIS LE Manager interface has been designed to simplify learning and speed model setup for the user. The menus and layouts in each module have been designed so that similar commands will be found in the same menu in each software module.
All menus have been laid out in a left to right format. When you start setting up your model you will start with menus on the left, and as you progress with your modelling you will move through the menus from left to right.
