In these challenging times when COVID-19 is imposing significant disruptions to day to day activities and affecting normal business flow of our much-valued users and employees, we at Bentley are mindfully committed to ensuring a smooth transition of work from the office to a remote location or home. Our innovative software and services are all geared for working from home or remote locations and do not impose the need to be in an office set-up.
For a general overview of how this works for Bentley products refer to
To ensure a smooth transition of work and effectiveness of your daily workflows with SOILVISION, we have assembled information that you can refer to while working remotely or from home. We are working hard to deliver high levels of customer service, and welcome feedback, questions, and ideas on how we can serve you better in a remote work environment.
You may decide to install the software on your home computer. If you do this, once signed in via the CONNECTION Client using your normal work email login, you will have the same licenses available as you do in the office.
There are several options to work remotely. You may decide to install the software on your home computer. See these minimum machine requirements for:
All Bentley software is downloadable via the Bentley Software Downloads pages: https://softwaredownloads.bentley.com/
General download and installation directions are available here.
Service Request Manager for any technical question and support.
Our technical experts are ready to help
https://apps.bentley.com/srmanager/ProductSupport
Bentley Communities (WIKI and FORUM):
This WIKI and the Forum.
CONNECT Center
https://connect.bentley.com
