| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Edwin Yepes, Bentley Technical Support Group | ||
I have a PDF file with a 3D object and when I display the file in Acrobat Reader 7.0 the "Model Tree" is not being displayed.
User needs to have at a minimum Acrobat Reader or Acrobat Professional 7.0.7 in order to be able to see the "Model Tree".
