| Version(s): | 08.11.07.115 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Edwin Yepes, Bentley Technical Support Group | ||
I'm using MicroStation V8i and when I print from Print Organizer my custom line styles and Custom fonts are not plotting correctly.
User is using a modified shortcut to invoke MicroStation. The target reads:
"C:\Program Files\Bentley V8i 08.11.07.115\MicroStation\ustation.exe"-ws_ustn_site=J:\Resources\CityWorkspace_V8i\ -ws_ustn_ecappl=J:\Resources\CityWorkspace_V8i\appl\EngServ\Civil\
Here is the process we go through in Print Organizer:
Print Organizer first looks at the MS_PLT_ENGINE_CMDLINE_ARGS (New in version 08.11.07.115) variable. If defined, the command line arguments in that variable's value are placed on the command line used to launch the worker process.
If MS_PLT_ENGINE_CMDLINE_ARGS variable is not defined, Print Organizer looks at the MS_CONFIG variable in the interactive session. If defined, it launches the worker with the same -wc command-line option that was used to launch the interactive process.
So for this particular case the variable was set as follows:
MS_PLT_ENGINE_CMDLINE_ARGS =
-ws_ustn_site=J:/Resources/CityWorkspace_V8i/
-ws_ustn_ecappl=J:/Resources/CityWorkspace_V8i/appl/EngServ/Civil/
